Crossfire With APU?
Hope this is the right forum for this. Ive got an A10 6800k and a 6670 hat I'd like to run in crossfire, do I plug my video cable into the motherboard, or the GPU? How will I know its running crossfire, and not just one of the two? Thanks in advance for any help.
What video cable are you talking about.  The one that goes into your monitor?  And to set up dual graphics you have to go into catalyst control center with the gpu installed and there should be a section where it shows the option to enable dual graphics.  I try to find a picture.
EDIT: Picture -
Sorry I misread the question I don't think that it matters what you plug the cable into I would say the gpu but like I said I don't think that it matters.
Awesome, Thanks for the help, I had the wrong version of catalyst installed
No problem have fun with the xtra performance:D
