Crossfire 7970/280x vs 780ti
Thinking about selling my Sapphire 7970 ghz and Asus 280x for a 780 ti. What do you guys think?
If you didn't already have the cards I would say go the 780ti BUT seeing as you already have them it is not worth upgrading imho.
If you already have them crossfired, don't bother, unless you have a reason to go with a single GPU.  Crossfire'd 7970s provide stronger performance than a 780 ti.
Reason being, I've had quite a few headaches with Crossfire. I seem to have gotten everything to a stable point, but I am harrowing the next driver update. I'm wondering if a single card might give more stability, and maybe make my setup a little more future proof. Thoughts?
1. new games are optimized for AMD hardware (PS4 and Xbone have AMD hardware) : 1 point for AMD (see BF4 Mantle support... also : see project MANTLE from AMD).
2. you need very reliable cooling : 1 point for AMD & for NVIDIA third party vendor versions AND -9000 points for AMD & for NVIDIA stock design boards  :)
3. you need as much VRAM as possible (Skyrim will eat VRAM like a MOFO): 1 point for AMD
If you light cigars with 100$ bills just ignore the rest of the text and go buy quad SLI NVIDIA 780ti :)
result : 3 points AMD vs 1 point NVIDIA --> recomendation : R9 290X .... but, you might want to wait for a couple of weeks for ASUS and MSI to release the custom cooling R9 290X boards ( very strong chances some third party vendor will release a closed loop water cooling solution )
if you want some info about  ASUS Radeon R9-290X DirectCU II OC you might want to take a look at this : http://www.guru3d.com/articles_pages/asus_radeon_r9_290x_directcuii_oc_review,22.html
I've never been much for AMD cards, they have patchy drivers and generally hotter/more power hungry.
While you'll probably see some performance drop going to a 780Ti if you want to save some power and have better driver support I'd recommend it. And it avoids all the hassles of crossfire.
New games aren't necessarily optimised for AMD, I'm pretty sure there's just as many claiming to be optimised for nVidia. As for Mantle, I wouldn't really consider it yet because we have absolutely no real benchmarks of it (that I'm aware of). It could do absolutely nothing for performance (though that's unlikely).
Aftermarket coolers are admittedly fantastic, but reference coolers still function just fine unless you're in a very bad case.
More VRAM is good, but it really only becomes important for maintaining performance at much higher resolutions. I don't think there's going to be much difference between 4gb and 3gb.
As for that graph, you can see the 290x is labelled as overclocked. The 780 Ti isn't. I think if the 780 was overclocked moderately you'd pretty easily get more than the 101 points difference.
TL;DR: If you're okay with the moderate loss in performance in return for lower case temps and less power consumption, less driver issues and no crossfire hassle, go for it.
I am expecting a slight performance hit, but given the outright hassle of crossfire, I don't see how it can be that bad. So many games have such poor vsync'ing issues and I constantly have to play with dozens of values so that crossfire quits complaining. Like, for example, I was getting horrific screen tearing in Scribblenauts Unlimited, a game I could play on my cellphone cpu. It took me half an hour of switching, disabling, to get the perfect profile for it. And for whatever reason, CCC routinely just changes my settings or doesn't recognize it's running a certain .exe. It's so frustrating.
So I mean, yeah I guess my firemark score won't be as high, but I feel like I'll be getting better performance overall. I keep my case extremely cool. Even my dual AMD cards rarely crack 30-40 C under average load, and are usually sub 25 idle.
Can you speak to the drivers on the nVidia side? I've been AMD forever, but this crossfire setup is just such a goddamn constant hassle of getting things JUST right for every single game.
Honestly this is probably my biggest worry. That if I switch to an Nvidia setup I'm going to lose a lot from the new consoles being strictly AMD. Can anybody speak to this?
You know, honestly, my Crossfire setup just gets terrible FPS in Skyrim with tons of mods. I have no idea. I believe the boys at Tek Syndicate actually did a playtest (with dual 280x's, my setup) of this, and I am getting really similar results. And the 1 GB extra with the 290x is nice... but, realistically by the time games are really implementing full 4GB of vram, I could probably just SLI a 780ti.
And firemark scores are nice, I get in the top ~96-97% with my current setup, but for me, they don't really translate into real world performance all that much. My crossfire setup has to be constantly maintained to work properly, which isn't dealbreaking necessarily, but it'd be nice not to have that headache.
If it's too much of a hassle then take the $$$ hit and grab a 780ti but I'd recommend waiting to get a better non-reference version of the card. G-sync could be useful to you later on down the track if you get a compatible monitor later.
Unfortunately I have zero personal experience with nVidia drivers excepting those on laptops (which were bad but on laptops so kind of apples to oranges).
How much room do you have in your case? MSI have released the lightning 780 (not 780ti) which is a 3 fan version of their twin frozr designs, I'd suggest they'll be looking at doing on e for the 780ti soonish. The problem with the non-reference cards for nVidia is that they nerf the bios for them so they are 'stability optimised' so if you want to get full performance you have to flash the bios of the card and possibly negate the warranty.
The nVidia drivers are nearly always hassle free. Been using them for years and there's never been much issue. Certainly nothing serious. I'm using two GTX 680s now and there's been nothing out of the ordinary with SLI either.
My friend has two AMD cards of some description and he's very excited to upgrade to nVidia and get away from the driver issues.
Get a 290X under water. A 290X under water will be faster than a 780ti under water. AMD made their cards useless because of the coolers. My 7800GTX is faster than a 290X without an aftermarket cooler. The 290X will run at 200MHz because of the temps.
Ignore all these people that say one is faster than the other "under certain conditions". Many review samples have been shown to perform 14% faster than their retail counterparts. So in short, if you're viewing benchmarks of review samples, that doesn't mean shit. The wool has been pulled over our eyes once again. There's a possible fix with a BIOS update, but again, there are discrepancies with some cards.
Even with watercooling, because no single card overclocks the same. And there are too many discrepancies with this cherry-picked samples. And some of these AMD cards do not overclock at all. There has been a huge uproar concerning the 290x, that people have conveniently ignored. I believe Nvidia cards are fairing a little better in that regard.
It is actually harder to determine which is faster and why. It is hard to determine how much faster they are.
I would go with whatever is cheapest, if you are determined to go with single card route. However, there isn't anything your current configuration couldn't handle. Even at higher resolutions. Problematic games, such as Skyrim, that do not take kindly to dual GPUs would certainly benefit. But a single 280x at 1440p is just as good as a 780ti if you're running mods. It seems that Skyrim mods prefer AMD drivers greatly.
Watercooled, both at STOCK clocks.
That means nothing. Why on earth would you fail to overclock cards and determine what is better value for money? No. Let's give the OP a lot of food for thought so he can make an informed fucking decision.
