CrossFire 270x 4G
Would a Corsair GS 700w power supply work with two 270x's?
Edit:i have fx 4100, asus 990fx r2.0 pro, and 8gigs of ram
yeah that power supply will be fine, however your cpu could potentional be a bottleneck here, that is something to keep in mind.
Then again.I would just recommend getting the r9 290 over the 2 270x
yes agree but a cpu upgrade to FX8320 would not hurt for him either.
cause 290 with FX4100 is a bit unbalanced.
so yeah maybe a FX8320 + R9-280 is something to concider.
280 = 7950, its on the same price range as the GTX760. But it will perform alot better then a GTX760, or 270X.
yeah.the 8320 plus the 280 is a better option.Just wondering can the 280 be unlocked to the 280x
im not sure, but it don´t think so.
i know with some XFX 290 reference models you could flash a 290X reference bios onto it, to unlock all the stream processors, But with the non reference models they vannish´d this option. So i guess with the 280 and 280X its not possible anymore.
the reason i am thinking about crossfiring is because i already have a 270x
yes you can do that, but remeber the cpu could be a potential bottleneck. depending on the game´s you play.
i know something like bf4 which is more cpu powered would be bottlenecked... intead of a 270x i was thinking of getting a 6300 or a 8350 cpu
