Critique my (hypothetical) $600 build
Someone on these forums was asking about a $600 gaming build, including monitor. I started working on a build, and I refreshed the page to see if any new replies had been added, but it seems the thread had been deleted. So, since I'm bored, I just thought I'd post it here and get feedback on it. Bear in mind that it is theoretical, I'm not actually buying it.
http://pcpartpicker.com/p/3rlRG
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor ($79.19 @ TigerDirect)
Motherboard: Asus A88XM-A Micro ATX FM2+ Motherboard ($78.99 @ Mac Mall)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory ($63.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($56.99 @ NCIX US)
Video Card: Sapphire Radeon R7 265 2GB Video Card ($165.99 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($37.99 @ Micro Center)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($19.99 @ Newegg)
Monitor: Acer S220HQLAbd 21.5" Monitor ($99.99 @ Amazon)
Total: $603.12
Basicly it looks good, not much to argue about. its definitely balanced.
i personaly allways try to set a FX6300 with an Asus M5A97 R2.0 in a lower budget system, but that wil cost more. FX6300 will stretch his legs more in games like metro that lean alot on the cpu aswell. But still those games are totaly well playable on the Athlon 750K with that entry level midrange GPU.
But honnestly for the price of your build there is nothing to argue, its just a good balanced, lower budget system.
Like Angel said, there's nothing wrong with it.
Only thing I would change is the RAM, simply because there is cheaper RAM out there:
http://pcpartpicker.com/part/gskill-memory-f31600c9d8gao
I agree with fx 6300 as an option... Especially if you are going with cpu, not an APU...
