Hello everyone.
I am in the middle of choosing parts for my computer. Even though I built a PC in the past because I moved a few times I left that system behind. That means I am building a system fully from scratch including peripherals and display. I already acquired good headphones, and mouse and expecting keyboard as a gift, but didn't choose it yet (Razer Blackwidow Chroma Maybe?).
This is the build I have in mind:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor (£274.74 @ Aria PC)
CPU Cooler: be quiet! Dark Rock 3 113.8 CFM Fluid Dynamic Bearing CPU Cooler (£49.98 @ Aria PC)
Motherboard: Asus X99-A/USB 3.1 ATX LGA2011-3 Motherboard (£201.65 @ Dabs)
Memory: *Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory (£107.99 @ Aria PC)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive (£58.74 @ Aria PC)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Extreme Video Card (£602.78 @ Ebuyer)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (£71.95 @ Amazon UK)
Power Supply: Corsair 850W 80+ Platinum Certified Fully-Modular ATX Power Supply (£134.99 @ Ebuyer)
Case Fan: Fractal Design GP14-WT 68.4 CFM 140mm Fan (£9.80 @ CCL Computers)
Monitor: AOC G2460PG 144Hz 24.0" Monitor (£296.99 @ Aria PC)
Total: £1809.61
Prices include shipping, taxes, and discounts when available
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2015-07-08 16:31 BST+0100
To give you a little bit of a background about how this is build will be used:
I am planning to use this system for all my work and entertainment needs.
I am a software developer so will be using this machine for whatever software projects I come up with which would usually involve running visual studio and SQL server. I am also notorious with my internet browser habits, I'll have at least 20 tabs open after 5 minutes of browsing. Plus skype, torrent and other programs, so I have no trouble hitting 8 GB of RAM just by doing that. That's why 16 GB.
I might do some video capturing/editing but not sure how I often I will do that yet.
I am also planning on gaming with this system and even though I will have one display initially I am planning to buy additional two afterwards for some surround gaming in simulator games like StarCitizen and newest Need For Speed. I am not shy on dialing down some settings to get high frame rate so I am not to worried about not be able to run any games in the near future, and I can always fall back to single display with high AA settings if required. Plus G-Sync should help a lot with any frame rate dis anyway.
I am also planning to hook this PC to 4K TV, that is in the same room but mainly will be used watch movies and TV Shows (maybe some playing some RPGs like Witcher 3 if I feel like it). I wonder how crazy it would be to hook one 1080p display and 4K TV, and how much crazier to do
this with triple monitors and 4K. I am OK with disabling additional displays in software, but can I leave cables. But would like to know if I can operate 3 displays or at least one while someone else is watching movie in 4K on TV.
So I as I just mentioned eventually I am planning to buy two additional 1080p displays and run them from the same 980 Ti video card, or maybe buy second one for SLI if required. I am concerned about 28 PCI lanes on the CPU of my choice, will these be enough though.
With this setup I am also not sure about SSD for my OS. I could go M.2 instead of SATA. From what I read M.2 uses 4 lanes though. Not sure if this would give me any tangible benefits.
I assume even with SLI setup PCI slots would look like x16/x8/x4 which should provide enough bandwidth. From what I know SATA express would use PCI Express lanes, but the WD drive I chose uses SATA 3.0 which does not require any PCI Express lanes.
As you probably guessed I am planning to torture this system quite heavily, so I will be overclocking CPU to at least 4.0 GHz, but it's quite cool at my place I might push it to 4.4 for stable operation. GPU will be overclocked if stock performance will be not as satisfactory before I consider investing in SLI.
Having all of the above in consideration I still would expect the system to be quite especially while watching TV or browsing Web. I do understand that this system will be audible when playing games but I am not as worried about that as I am planning to use headphones.
I am planning to add additional fan in the front to create positive pressure in the case. I don't want water cool my CPU even with AIO cooler, as I feel it's more risky and a bit noisier. AIO solutions have 3 sources of sound (and points of failure) as opposed to one.
As for Operating system, I didn't factor it in the cost, because I get it for free with MSDN's Developer license.
So... am I heading in the right direction? How realistic my expectation about what this system could achieve?
Any changes, suggestion, critique will be appreciated. My budget initially was about 1500 pounds for a system without one display and, but I guess I can push it up to 2000 pounds for everything (PC+Display).
