Ok so let me start off by saying that the thing worked perfectly like a day or two ago, but today for some reason didn't make any changes in the way my headset sounds. So to the problem:
Clean install of the OS install the drivers from the cd (everything works perfectly fine)
-Today for some reason THX TruStudio Pro no matter what i change the sound is no different. So i Uninstalled therealtek driver and the Creative SB X-Fi MB2 driver (sound blaster+ THX) and downloaded the latest versions and installed them, but wait after installing them they're both saying that they cant find supported audio devices.
-All the drivers are installed, Sound is working but the Sound blaster Control panel and THX TruStudio Pro keep on teling me that they cant find supported audio devices? What's the catch here, because the only way to fix it is a fresh install of the OS, which i will do if i cant find any other solutions.
