Hi, in advance sorry for my english i'm french ... anyway,i'm willing to build a pc gamer (only for gaming besides of course surfing web etc ) and i'm really confused on what to choose,as you know the next gen is here and with it games will be very likely much more demanding than the last gen in the futur,what do you think i should buy (cpu+motherboard+ram+graphics card) to always be able to play games fluently without much compromise in graphics quality ?
you should also know that my budget is very restricted,wich mean that here in france,i got two choices,getting an I5 with 8gb of ram and a descent motherboard and run it with my old HD5870 in order to get more money for a new graphics card (like a GTX760 but not more,i'm only playing at Full HD and that doesn't bother me if i disable AA) OR as for the second choice,getting an I7 with also same motherboard and ram memory but i will stick for a very long time with my HD5870?
you must understand that i'm a student and these things are very expensive here,thanks anyway for you futur advices.
PS:AMD FX processors are not possible choices for me because they're not available here (pretty much the same price on the net as I5 and I7 so...).
