Am I able to redesign the icons for some programs? I don't really like the way they are atm..
Just wondering if it's possible, if it is, how should I do it?
thank you
thank you
I guess an easy way to create icon files are with the online ones such as:
http://www.rw-designer.com/online_icon_maker.php
It's easier to change the icon for shortcuts if that helps at all.
You can adjust icon settings globally in /usr/share/icons/foo and usually just by adding a correctly sized .png file to the appropriate folder. This works as long as your naming convention remains the same as the target application.
When you're targeting strings such as; -run "foo" %F the above method won't work. In this case, you'll need to create an application launcher or .desktop file which includes an option to point to an image file (transparent .png) or icon file that follows standard icon ruling ie; 128px128px etc. This method is standardised by freedesktop.org with Gnome, KDE, LXDE and XFCE.
Yeah I just want to change the icons. What size should I make them at?
There is no "foo" in my icons folder...
I believe the DE of ElementaryOS is pantheon, does that matter?
so all icons need to be 128x ?
thank you
