Hello L1T! I have been a fan since the dark days and have always watched devember from the sidelines. This year is different.
My devember project is creating a VCU board built around an ESP32 (for now), It will be leveraging micro-ros and FreeRTOS frameworks and tools to create a smart vehicle control unit for Voltron Mini, a miniaturized version of a full size go kart of which this project will be the predecessor of.
What is involved in the low level system:
- micro-ros integration
- RTOS research and integration
- PCB design
micro-ros research and documentation
I think that we should be able to work initially with the raspberry pi pico without using an RTOS just to get familiar with micro-ros.
benefits over ros-serial:
- ROS 2 tracing
- we can easily monitor and visualize callback durations
- Benchmarking with the Shadow-Builder | micro-ROS
- supports middleware
- the core functionality of micro-ros relies on the same implementation of the core concepts of regular ROS2
- parameters
micro-ros development notes:
link to ros2 docs (for galactic, which is the version we are using):
https://docs.ros.org/en/galactic/index.html
- getting back to work with micro-ros and the esp-32:
using this as a component to esp-idf:
- at first had trouble getting through to building a new test project that leverages micro-ros
- was getting stuck at getting the micro-ros component built in the first place, as I copied over the micro-ros component repo from github to the components directory within my local esp-idf
- the build seemed to be erroring on ament_cmake_core for some reason, tried sourcing ros2 which shouldnt be necessary, and this didnt help
- in the end, I just used get_idf again and after a idf.py clean-microros and was able to get a build finished (although )
- cool, was able to get the first standalone micro-ros component using esp-idf framework example built
- had to include some menu configs that werent called out
- goal 1:
- create micro-ros task that publishes data
- goal 2:
- create a task that talks to another task using micro-ros pub-sub (between freeRTOS tasks)
- goal 3:
- get parameter server working (bonus: get rqt_reconfigure working as well which is a parameter gui)
Largely, this project is encapsulated in the following high-level system diagram:
