the weirdest thing I have seen so far is the "dunk your pc in oil" method of cooling and a car lighter and cup holder that fit in a 5 1/4 inch drive bay. what other crazy mods have you seen?
PC in Oil, is the dumbest idea possible. Well if you're using Vege oil your going to get rubber nasty coatings and if you use mineral oil its expensive and eventually going to seep out, no matter the matter. I like the Cosmo mods, not really crazy ridiculous, but the Cosmo case rocks.
yea i've seen those videos of an oil cooled PC. seriously? no fuckin thanks.
lmao, oil=fucked up.
Every component of a PC hermetically sealed and submerged in water.
Oil is not conductive making it perfectly safe for any electronic equipment to be submerged. Heat is transferred via radiation and is spread throughout the oil. However, this is not enough to cool the CPU.
There is a special block for the CPU which sucks in oil and blows it out. The entire oil case is then cooled by an ionizer which neutralizes molecules from its fast pace, stopping heat.
Do you guys think I'm getting this from the internet? Nah.
It doesn't matter Rice. Even on idle your computer will get smoked. 80C+
is there a way I can make some kind of security system in my computer? like a fake power button thats actually a FLAMETHROWER
that would be awesome
@ dead hand
