Crazy question
Now heres a really Crazy question that not many people see these days!
The AMD Phenom II X6 1045T is a 6 core cpu for only $100 plus a motherboard that cost about $60.
And planing to OC some, the test arnt bad. It's in a price range i like.
Its a BIG upgrade compared to my Duel-core pentium, clocked at 2.93Ghz.
So for a small upgrade, I feel pritty Confident in! Can anyone beat this for around $150 upgrade? Performence /price.
Really am debating between a few Cpus/Motherboards and this one for the Price is doing a decent Job!
No, that's not a bad choice, It'll be pretty good for the price. You really should take some high school level english classes though.
Thanks mate, :) English isn't my best major. at all.. but i try.
  I am curious as to which motherboard you are using along with that chip. Newegg no longer carries the Phenom II X6 and only stocks the Phenom II X 4 and they want the same price for it.
Its a Asus Micro Atx motherboard, very nifty.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
Sold! You are not going to beat the price VS quality of what you got. Go for it.
