Crazy cooling setups from the past
Just curious what ludicrous setups you all have ran in the past. The most absurd or overkill only please.
Several years ago I ran a generic mid-tower case that housed an ASUS A7V board with a Duron 600Mhz overclocked to 927Mhz. I had a massive copper cooler on the CPU and a slew of fans. I can't remember the GPU in this system for sure, voodoo3 is the only one to come to mind.
Anyways down the the nuts and bolts.
Mid-tower case
2 PSU one mounted internally and another bolted to the top with the wiring routed behind the optical drive
1 generic 80mm fan for casual use
2 radioshack 120mm 12v metal case / blade fans that moved 83cfm. That's not a typo, they sounded like a plane taking off a runway. These were the reason for the second power supply. I used an automotive switch to turn the second PSU on and off that was mounted in a 5.25" panel cover.
Massive copper cooler thermaltake or thermalright, something like that here is a picture of what it looked like.
This was also my LAN party rig. To say the other people there were concerned was an understatement.
I have a cardboard wind tunnel for my gtx 280 because it runs sooo hot and needs its own dedicated cold air intake
