My Siberias V3’s started to make Crackling/Popping noises, it’s only in the left ear cup and after unplugging it, it kept making noises so it can not be a plug or the on-board sound. When I don’t move my head it stops slowly and when I move my head it crackles more and faster. It seems to me as if gets worse and worse and it’s already annoying enough… Suggestions on what might be causing the issue?
Neutrinos.
Broken cable
Check for other speakers or phones near your audio cable because magnets in these devices can cause static noises, I don't know if this goes the same for popping noises though.
How do I do that?
blown diaphragm or cable is disconnecting at one end.
What I realized is that when I disconnect it and it keeps doing the noise, by pressing the earcups together so the air gets blown out and in it stops.
It is probably the cable
Try pushing it up into where it enters the headphones and hold it as you move your head around. If this works you know its the cable or connections and you might be able to tape it in position for a temporary fix.
