Cracking and hissing from MayFlower O2 dac/amp
So like the title says, its begun to start hissing and cracking randomly. Sometimes turning it off and back on fixes it but it always comes back. Has anyone else had this issue with it?
Sounds like it might be a bad solder point somewhere. Open it up and look at the underside. Post some pictures if you aren't too familiar with soldering.
well if that's the case, if I can exchange it. Then I'll just do that instead.
Are you using USB 3.0? USB 2.0 works much better with the ODAC. It could also be a bad USB cable. Shoot us a message on our website and we can help you troubleshoot your problem.
