Hello everyone! First post here. I built a PC about a year ago, but it was nothing but troubles.
[URL=http://imgur.com/MBDkV][IMG]http://i.imgur.com/MBDkV.png[/IMG][/URL]
First of all it has an annoying beep sound when I move my mouse. Sort of like a morse code. As far as I found out I have to live with that, nothing to fix that.
So here goes my questions:
- My PSU (CORSAIR TX650 V2) has some veird voltages. The 12V rail stays 11.7V idle, 11.6V full load, is that normal? Also are other voltages good? [URL=http://imgur.com/o85uR][IMG]http://i.imgur.com/o85uR.png[/IMG][/URL]
- If i reset my PC, or get a bluescreen I always lose data from M4 SDD. Like when I boot up after: do you want to allow skype trough firewall, jing settings lost, configure? almost all apps lose their settings.
- Sometimes my MOBO does not see my SSD, like its not connected at all. I reset the BIOS or change the SATA port ant it works.
- Sometimes my USB does not work, the mouse or keyboard does not light up, I reset and it works.
- Warnings pops up like your VVDA is at 0.12V. Or other crazy numbers. No bluescreens.
I also had tons of problems with my radeon MSI 6870 Hawk. On reviews it OCed to 1150. Stock 930. I was able to get to 975 stable, more and the artifacts show up. I paid a lot for OC potential on that card, now it started to black out. Display driver stopped. I tried reinstaling OS, put it in a different PC, same results, constant hangs. (it is currently in service)
I am quite sure I made the wrong choice selecting my motherboard, but I can not send it to be repaired, it sort of works 90% of the time and I was unable to replicate any problems, they just happen. I tried upgrading BIOS, no improvement. Also maybe it is the PSU?
(I tried bringing working electronics to a service center here in Lithuania, every time they get back. It was tested and working. The don't care if caused you problems, it has to be dead to be replaced, or something like the usb does not work at all)
Sorry for my poor english, I hope you understood. Please answer any questions from the dotted list, thanks. :)
