I am in a dilemma! I only have 470USD or 350EUR and i need a upgrade!
My current specs are as following:
Q6600 8GB RAM 680i LT Motherboard 560 Ti
I am at this moment looking for a cpu upgrade. I was thinking about buying a 4670k and maybe a B85 or H87 motherboard though I know they won't do much when it comes to overclocking, but what do you guys think?
Please note that I am located in Denmark so if you suggest something in a store please make sure it's a european store.
Wanna get the most bang for your buck? Get an Asus maximus IV Gene Z z68 board, flash the bios, then drop an i5 3570k in it. Or if you don't want to flash the bios, get an i5 2500k.
You'll be able to overclock well over 4.5ghz on that board. And best part? It's $80 for the Asus Maximus IV Gene Z and $150~$170 for an i5 2500k.
Well, I've been hearing some bad reports regarding recent 8350 purchases. Apparently with the 9*** series FX processors (which are just high binned 8350's) that good OC'ing 8350's are a thing of the past!
You will probably still be good for 4.5-4.7ghz ish but I can't say. Currently I'm sitting at 4.7ghz on my 8350, only limited by thermals.
FX8350 mostly overclock like a champ on the Asus M5A99Fx pro R2.0 you would be able to get 4.6 GHZ stable without any pain, if you want higher numbers 5GHZ, then i would recommend a better mobo, like the Sabertooth. is FX8350 is one of the best overclockable cpu´s arround at the moment. for consumer pc´s. i dont hear bad things about overclocking the FX8350. offcourse you allways need a bit of luck, but as long as you not cheapout, on main quality parts of your system, it wil overclock verywell.
