Is an upgrade from a Pentium D dual 2.8ghz to a Core 2 Duo 2.13ghz (the e6400) worth it? Seeing as the pentium d has higher clock speed and more cache. But im guessing the newer generation core 2 duo has better architecture. Need answer asap.
Seeing as i have a very limited budget and i dont have a i7 compatable mobo im gonna get the e4300 for £60 (most likely attempt a 3.0ghz clock), seeing as my current processor bottlenecks my 4850 alot atm i just need this one to tie me over till i get my new rig, ty for help neway guys.
60 pounds =/ and wth... the cheapest e8200 i can get is 100-120 pounds and england sucks for pc components and if i ordered from america the 15% VAT + import tax + larger postage costs make it about the same price here. Sucks to be here.
You'd be better off getting the E8400, but if your budget is that limited, yes there will be a nice and very noticeable difference going from the pentium D to the E6400.
Another option is the E7400. 109 USD on newegg, FYI.
Heh thanks for that xD found out it didnt support 45nm cpu's, since i found a little bit more money i was gonne get a e7200 but that would have been a big mistake. You saved mah!
Anyway im gonna get the e4500 and a coolermaster hyper tx2 fan and OC it to about 3/3.3 seeing as it has a 11x multiplier.
This is just till i have enough for my whole new build but seeing as the new GPU's are out soon id thought id buy a CPU for the time being then just build a new one when i can. Ty for help guys.
You'll probably only get to about 2.8Ghz. My friend has the same CPU, and a crappy Mobo too, expect Asus. Both really cheap shit, when he got it to 3Ghz all his onboard shit stopped working, and that was with an Intel Chipset.
 Processor:  Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® D, Pentium® 4, Celeron® D processors, Socket T (LGA775) Or he must change his mobo then.
I checked to see prices... so ive decided to buy a phenom II x2 545 (soo much better than e4500) and a am2+ mobo (will need bios update but thats no problem) Got the phenom oem for £55 and im getting a asrock K10N78M ,i no its another cheap one but it has alot better features comapred to my mobo atm. Comes out to be only about £10 more than the e4500 once i flog off my current mobo/cpu, some1 is bound to be stupid enough to buy ebay stuff.
