CPU Upgrade - Help Needed!
What is the BEST processor you can get that will run Arma 3 on maximum settings in multiplayer. (Varies from server to server, I know.) I also want to record and edit videos too.
I've looked at the FX-8350, but unsure of all the mixed reviews and don't want to take the "risk" then be screwed when it can't play Arma 3 any better than my X4 945....
I've also looked at the i5 4670k strictly for gaming and light editing.
I've also looked at the i7 4770k for the gaming and video editing/rendering combo. Is it worth the extra $100?
What's the best choice? Thanks for the help! :)
EDIT: I also have a 7870 GHz Edition video card just so you know. :P
If you can afford it then I'd personally say go with the 4770k provided you make use of it being unlocked and oc it.
Yea, I want to. But I'm not sure how much I want to spend as I'm adding this along with a bunch of other parts I have already picked out.
The problem is I'm not getting a cheap motherboard so the money adds up. I just dunno if I can do all that perfectly with a i5 4670k or FX8350.
An 8350 is better than an I5 but the I7 is king
If you wanna save money, but still have the good gaming performance and editing performance, I would say the FX-8320 is a better choice than the 8350. You say you're getting a good motherboard, so you can just very easely overclock the 8320 to 8350 speeds and even beyond that. The 8320 is basically an underclocked and dirt cheap 8350.
However If you have the money and wanna spend it, the i7 is the way to go as you get much better performance out of the box. It depends if you wanna spend more into something like an SSD and the GPU.
Already have 7870 GHz Edition so the money would go somewhere else. :P But the budget is a major factor as I can buy parts over time and especially if they hit sales.
The problem is that I don't want to buy a FX-8350/FX-83520 and then not be able to play Arma 3, Arma 2, and Planetside 2 on maximum settings on 1080p with 30-60FPS+.... I dunno if I want to take that risk, but I don't want to cheap out on the motherboard because if you do... there goes your whole system.
But I'm also lenient on buying the i5 4670k because of video editing/rendering. Not as good as the i7, but I'd like to record and edit 1080p videos if I can, but my current processor only takes about an hour or two to do a standard 720p 15 minute video.
Then I'm worried about the i7 4770k's price coupled with a decent motherboard, which also costs a bit of money. The money adds up and even if I do buy them over time, that's a lot of money.
I'll look into the FX-8320 and see how it runs and edits videos. :)
Dude 3770k is still a badass cheap at Microcenter .
I have the 8350 and two 660s sli and I have absolutely no problems streaming other than my streaming program i dont like very much,(xsplit). editing isnt that much different either and for the price ill wait a couple more seconds.
Personally, I would go with the FX-8350. I have one. It is OC to 4.8 GHz and it is a beast. I also have a 3570k.
In ARMA II: Operation Arrowhead which is what I have, the 8350 wins hands down. This is also supported by the Tek SYndicate video about the 8350.
It also works well for editing and is much faster than the i5 for rendering and H.264 encoding.
The 8350 will be much faster than the Phenom II you have and will preform admirably in pretty much any task you throw at it. The price to performance ratio on the i7 isn't very good either. Especially if you are gaming.
What are your frames like in Arma 2 if you know? 30FPS+ is a MUST for Arma at the least and I always run 20 or lower. :/
Do you happen to have Arma 3?
8350 is plenty for Arma 2.  Strong CPU.
just make sure your GPU is decent.
I use an fx 6100 and play planetside 1024p with mid/high with almost always 30+fps , even the bad cpu optimization for that game, soon I'll get to an 8320 too, it seems a good cheap procesor
im not complete sure, but i thought that Arma is a typical intel favour game. The engine of this game is very CPU demending less GPU if im right.
please some one correct me if im wrong.
You're correct. Arma is more of a CPU intensive game than a GPU one, but a good GPU is still needed for the high end graphics that it has.
Arma brings a lot of high end systems to its knees unfortunately.
+1
3770k is just a little behind the 4770k. The main difference between the 3770k and 4770k is the iGPU
If you can, go with a 3770k and decent z77 motherboard (please avoid the non-gaming MSI boards, i have had bad experiences with them)
yeah so if you realy love this game, and you want the best experiance with it, then probalby intel will be your best bett. but offcourse on a FX8350 its still playable.
I've got an 8350 @4.7ghz and I would not recommend it for DayZ SA and/ or Arma II. The 8350 is great for certain things, and after the recent Planetside 2 update there are really only three games that I can think of that this CPU will bottleneck performance on, even at 4.7ghz. Those games are GTA IV (because shitty port), DayZ SA (because it uses the Arma II engine), and Arma II of course. Here's the thing, it's an absolute monster at everything else, and as far as recording gameplay using something like OBS the 8 cores really come in handy, you won't see a frame drop even in games that it doesn't perform well in like Arma II. But as far DayZ, dear god is it bad. Same performance as my Phenom II X4 970 BE. It runs 60fps anywhere but cities/ towns. Seriously, running right next to the towns like Cherno you will see a massive frame drop just looking at the town. If you look away, you get an instant 20+fps boost, then look back and it's back to a laggy shitstorm.
i get arround 30 fps, on very high / ultra settings 1080p single player mode. FX8350 stock with 7870GHZ stock... so its playable, but no mind blowing numbers
in arma 3
I play Rift and that game sucks for my system. the cpu is the bottle neck but from what i hear the game engine is crap. it never wants to use more then 30% cpu power and not much higher on my two 660 TI's which sucks because i actually liked the game.
