Cpu temps jumping up to 44 Celsius
hey i was looking at hwmonitor and i was seeing my cpu (fx 4130) TMPIN2 jump up to 44 celsius from 34 and im looking at task manager and barley anything is using the cpu up at all and the main reason i was looking at that was the sound in my room from my fan is really loud
and this is at 49 celsius
speedfan
Over what period of time? Is the room air conditioned? If you're feeding it hot humid air there's going to be some variance. What was the actual fan speed %? I would look at replacing some fans with rubber mounts like something noctua sells before I turn them down.
the thing is i dont know what fans are in it i bought it off amazon and i dont even know what case it is and i dont think the room its in is hot but when my parents walk in they moan about how warm it is but the thing is i dont get why its jumping from 34 to 44 Celsius in a matter of seconds
Won't help, reads the same sensor.
@ninja85a:
CPU temp sensors are a bit temperamental, they do not really read constant temperatures (on my FX4170 and FX8320E at least). What cooler are you running?
im running the stock cooler
I thought he wanted a fan control app which is why i said that
