CPU Temperature Monitoring Software
Hey,
I just finished my build about a week ago and I was wondering what is some good software for measuring CPU temperature. Planning on overclocking my FX-8350 soon so I would really like to have some reliable software to monitor the CPU.
Pretty sure most people use CPU-Z or something. But I just use core temp. The actual core temp application isn't that compelling to look at, but it has an awesome widget you can slap in the corner of your desktop to always monitor your temps.
http://www.alcpu.com/CoreTemp/
http://www.piriform.com/speccy
http://www.almico.com/speedfan.php
http://www.techpowerup.com/realtemp/
the REAL TEMP does not support AMD FX 8350
[img]http://doomlord-quiz.no-ip.biz/blacklight/damn.png[/img]
I'd recommend not installing CoreTemp from alcpu.com since it also installed some shitty web radio software or something similar, I don't like when people try to shove unwanted software in my installs, this and when it tries to change my homepage to Ask or Yahoo. Alcpu; 0/10, would not install
I use HWmonitor, same guys who make CPUZ
http://www.cpuid.com/softwares/hwmonitor.html
