CPU Questions
Ok so on newegg theres an 8150 with a all in one watercooler. its the same price as the 8350. is it worth getting the 8350 instead of the 8150 wth the water cooler. if i get the 8350 ill haft to upgrade to a water cooler later.
Link to the 8150- http://www.newegg.com/Product/Product.aspx?Item=N82E16819106011
Well... The 8350 is better than the 8150, but I have no idea how good that water cooling kit that comes with the 8150 is. Don't know your budget, but a FX-8350 with an H100i from Corsair would be a very good combo I would say.
