I'm running a 4960K with a H100i AIO cooler. I've been running for months with no problems. As of yesterday I saw that it was running at 85-90C! I immediately turned it off and have been fiddling to try and fix the issue.
I installed a third HDD in the back of my case and moved the SATA power cables around in order to get them all to fit and that seems to be the last change before the overheating started. I thought maybe I pinched the cable connecting to the pump when I put the back panel on so I tried removing it, but the issue persisted.
In Corsair LINK the Pump is shown red and flashing, with no temperature reading or RPM measurement.
I hope you got a multimeter and two paperclips. Continuity check function and hook it up! (some resistance is okay, OL or Overload is not. 0 Ohms is bad aswell as that could mean the header is fried.)
Looks like the pump it's gone unfortunately. What you may try is to plug the pump into a different fan header on the motherboard, just to make sure the fan header didn't go bad for some reason. Good luck!
you dont need a receipt for microcenter. they keep crazy records and thier customer service is insanely good. Thay probably have your name, email and address attached to the serial number of the device :P
I'm going to give them a call tomorrow. I figured they had records like that and that'll be what I probably have to do. The AIO is guaranteed for 5 years so I imagine Corsair will send me a new one.
