So, the title says it all, im getting an h100i on monday in the mail. I already have 2 more cougar 120mm for it. I was wanting some advice into overclocking a cpu. What to do and what not to do would be a good place to start, and how did you overclock your cpu?
There are countless guides that you can find just by googleing "overclocking a fx 8350". You want my advice, have patience and run a stability test after each step.
FIVE GHZ ALL THE WAY!!! ALL THE TIME!!!
If you have a good Motherboard you should be able to get 4.7 by just changing the multiplier and upping the voltage.
here's a link http://rog.asus.com/216552013/crosshair-motherboards/guide-overclocking-fx-8350-to-4-8ghz-on-crosshair-v-formula-z/
