Will i be able to get a stable overclock of 4.0Ghz on i5 3570k, with a corsair h80, of will i have to spend a bit more for like a h90 or 100.
to mee it seems that a stable oc 4.0 ghz on the i5 must be possible with a H80, cause 4.0 ghz isnt realy an extreme thing.
ok thanks for getting back to me what target do you think i could reach, it has to be stable because i will be gaming over long periods of time.
well logan used in his movie on the i5 3570k oc the cpu without any trouble to 4.5 ghz with a H100, so i think if you go upto 4.2 ghz on the H80 it should be stable.
