Hi, I am looking for a AMD CPU and Mobo for my first build. And i might be getting comments that will say: "Heyy mann, You need to go intel mannn its so much betterrrrrr." And NO I WILL NOT USE INTEL. AT ALL. Its overused. I will use AMD and AMD only. NO intel parts. (Well intel BRANDED parts) and a motherboard that uses some of the AM/FM or what ever has a good cost to performance. And if possabe i would like bluetooth.
Thanks.
Samuroot1987
For the whole build? or these two parts?
Intel isn't a bad company. No AMD product compares to their Sandy Bridge-E processors. However, at an extremely steep price, SBe isn't an affordable choice. I recommend getting an 8350 and an Asrock Extreme4 990fx, or, if your budget allows it, an Asus Crosshair IV Forumla 990fx.
Well. I dont doubt that intel is is bad. I jsut dont like them. And. I just looked at the asus board. And on newegg its DISCONTIUED. :(
Only temprarily - it is still being made/sold, but stock is low and demand is high.
Actually. Im useing a prodigy so the asrock doesent fit.
And the ASUS doesent fit either
For CPU and mobo or entire build?
http://pcpartpicker.com/p/FlqT Build so far.
Hey, I think i might use a phenom II But the mobo i have wont accept it and... well with how much im posting on here i starting to think im more of a n00b but you know, its my first build. Can you halp with picking out a Mob that will work?
http://pcpartpicker.com/p/FIG3
Hows that?
Forgive me. I forgot the card and im also a noob.
Dumb that ridiculous SSD, dump the crap CPU...
For under $800, the build i have posted above cannot be beaten.
Im not playing the newest games so i dont need ALL of that newer hardware (im assuming im a noob at this as ive said before) and yes, thats most likely the best for the price but i just need something portable adn that will do. not something that mill max out the grapics at 1080 i want something that might max at 720 and play youtube vids at 1080. As far as what im playing I like kerbal space program, Dont starve, TF2, Occasionally the binding of issac and super smash flash 2.
