CPU Heat Sink Recommendations
Hi,
Im looking for a CPU heat sink that will fit in the Bitfenix Shinobi, and that fits an AM3+ socket.
any recommendations will help greatly, im also not going to overclock. The reason for getting a new one is because the stock one is too loud
Thanks!
a cooler master hyper 212 evo is a great low cost option, i have one in my build, which looks identical to yours base off of the description, same case and socket type, and for the moment no overclocking. it will keep things cool and quiet. also a slight overclock is possible. look around to find the cheapest price.
link: http://www.ncixus.com/products/?usaffiliateid=1000031504&sku=64385&vpn=RR-212E-20PK-R2&manufacture=COOLERMASTER&promoid=1263
Thanks! It helps a lot!
