CPU dilemma
I am soon going to upgrade my processor from an fx4100 to one of the following:
fx6300 used, £70
fx6300 new, £90
fx6350 new, £95
fx8320 new, £117
fx8320, used £90
My question is: should I buy used and if so, the fx6300 or the 8320?
The CPU will be matched with an hd 79x0 card, the x will be dictated dependent upon the remaining budget. Perhaps even one of the newer cards.
I would go for the new Fx-6350 or the new 8320.
Ps what motherboard are you gonna be using ?
I'm upgrading my old build, it is an Asrock 990FX Extreme3.
I must add that, thus far, this thing has been stable as a rock. I managed an OC of 5.2ghz on my 4100, just to prove I could, using only a single fan on a hyper 212 evo.
Good stuff.
+1 to get a new 8320. May it overclock as well as your old one!
used for 90$ seems decent for that 8320 i would go with it. Nothing wrong with used processors video cards is a bit more sketchy
Pounds, not dollars.
+1
As long as you know it hasn't been over volted (overclocked a bit is ok), go for the used 8320.
This is the first new processor i have bought for myself (fx 8350) in the past 15 years. I have had alot of luck with used processors. Money saved is better spent on a new video card cheers
Thank you, all. Will probably go for the used fx8320. The seller (eBay based) seems very refutable. I need now only hope it OCs as well as my old CPU
A quick follow up: the order of the fx8320 came yesterday, I am about to install it now and overclock the hell out of it. I will post details of any overclocks and if you wish, will also do a few benchmarks.
