Hi everybody, will the Be Quiet Dark Rock Pro 2 CPU Cooler fit in a GIGABYTE GA-H61M-USB3V Intel H61 mobo with the Sharkoon Bulldozer Black/Red Mid Tower Gaming Case. I believe my case is UK only. Thanks in advance! :)
It will fit in your case by over a centimeters marigin, I can't easily check the motherboard myself though but a dark rock PRO would be tight since there are 2 fans. a regular Dark rock 2 would probably fit it's 10cm measured between the I/O and RAM slots, while the "PRO" series is measured 15cm. fan itself is about 3 cm thick. This is how my own Dark Rock 2 looks like on a ASUS Maximus VI HERO it's touching the RAM, not bending it though :> The fan could not be placed in pull due to the heatsinks next to the I/O panel. It's a big cooler ;S
