ok my pc goes up to 80 C when i game
so i need a cpu cooler right now im am running my fx 8350 with stock cooler
temprature in case is 40 C
cpu temp on idele 45 C
on load 85 or more C
i was thinking to buy h80i i measured the space between stock cooler and 120 mm fan socket
it is 30 mm
so i do not think it will fit as the h80 i radiator only is 38 mm
so please suggest me a good air cooler thank u :)
Note : i can not return it if it does not fit as i live in india so please suggest me the right cooler which u think will fit in my case
and keep my tempratures normal when im gamming
the heat is too high here my gpu also run on 41 c on idele
My pc spec ~
motherboard - GA-970A-DS3
ram(8GB) [1600mhz] - Corsair CMZ4GX3M1A1600C9
processor - fx 8350
harddrive - samsung 1tb 7200 rpm
gpu - SAPPHIRE HD 7870 GHz Edition 2GB GDDR5
case - cooler master elite 310
supply box - cooler master Thunder 500W
