CPU Cooler?
Im building a new rig and i cant decide which cpu cooler im going to be overclocking an i5 3570k i want to get 4.5ghz i cant decide on a cpu cooler I think im getting either -
Intel RTS2011LC Liquid Cooling System
Noctua NH-D14 CPU Cooler
NZXT Havik 140 CPU Cooler
CoolerMaster TPC 812 CPU Cooler
If i go with a h80i i would go down to a 660ti is a good trade?
Hi, found this info it may help you http://hothardware.com/Reviews/Liquid-Cooler-Lineup-Corsairs-H80-H100-Reviewed/?page=3
Get the TPC 812. But if this is for gaming, and buying a cooler makes you go down a step in the GPU department, then I'd suggest not getting the cooler. Or if you can fit a CM Hyper 212 Evo( or +), it will do nicely and you can most likely get 4.5Ghz with it.
Also, I recommended the TPC 812 because it cools just as well as the more expensive NH-D14 and H100, while still being cheaper
i really want water cooling though
would the intel cooler be able to get 4.5ghz?
Hmmm. Try this. If I remember correctly, it's performance is in between an H70 and H80
cool thanks im probaly going to go with that, do you think my build will look good
Corsair Carbide 300R
MSI Z77 MPOWER Motherboard
Intel Core i5 3570K
Antec KUHLER H2O 620 CPU Cooler
Corsair Vengeance CMZ8GX3M2A1600C9R 8GB (2x4GB) DDR3
Galaxy GeForce GTX 670 GC 2GB
Kingston HyperX 3K 120GB Sanforce SATA3 SSD HDD x2
Seagate Barracuda 1TB
ASUS Xonar DGX
OCZ Technology ZT Series 750W Power Supply
ASUS Xonar DGX
Could you post the links? We may be able to find you better deals and such
Im buying all my parts from http://pccasegear.com/ and i have already bought my case, ssds and psu
One more thing. What do you intend to do with this build?
Just gaming and a bit of video editing not enough that i would need an i7
Really sorry, but one last. I keep forgetting these questions. What is your budget?
around 950 can be a bit over budget like 50 but try an keep it under
So you already have the PSU, storage disks and case? Also, it seems like you already have the sound card. So if that's the case.
AMD build: roughly the same performance, better cooling so you can really overclock this 8320-http://pcpartpicker.com/p/zoRi
Intel build: rougly the same performance, lower cooling performance- http://pcpartpicker.com/p/zoPZ
The parts need to be from pc case gear the link i put in an earlier post im in australia i cant order from those websaites
Ah, I see. Wow, Australian prices are high( at least, from my perspective)
Try this.
If you can spare $50, you can get a 680( albeit with less video ram, though it is faster in editing and games)
They're all from PCCaseGear, I just used pcpart as a medium to organize.
