Recently upgraded my case to a Thermaltake Versa H34 from a cheap Diablotek. The Thermaltake website says max clearance is 155mm for a CPU cooler. I have a FX 6350 with the stock cooler and will be looking to OC it once the cooler is upgraded, I'd like to stay with air cooling... any recommendations?
The tuniq tower 120 extreme would have good performance if you can get one. The nh-c14 would be a large top down cooler. The hyper T4 would be the budged variant (basicly a cut down 212), I think you can only mount it up on amd though.
