CPU Cooler Help!
alright so I have AMD FX-8320 processor, Asus M5A97 R2.0, and R7950 graphic card from XFX and housing for all of the component is NZXT Source 210 Window. I am looking for CPU cooler it could be air cooler or pre-field water cooler.
I've try to use my Hyper 212 evo, but it didn't work because of the height of the cooler. according to NZXT it support 160mm height of the cooler, but it doesn't with the window.
I do want to overclock my system (nothing extreme), so I am looking for a good, quit CPU cooler under $80.00 also I have amazon gift card, so I would prefer to use amazon.
Thanks in advance!
http://www.amazon.com/Noctua-Silent-Cooling-NH-U9B-SE2/dp/B0065SFEE8/ref=sr_1_33?ie=UTF8&qid=1388168826&sr=8-33&keywords=cpu+cooler
http://www.amazon.com/Cooler-Master-Hyper-TX3-RR-910-HTX3-G1/dp/B0028Y4S9K/ref=sr_1_4?ie=UTF8&qid=1388168856&sr=8-4&keywords=cpu+cooler
alright, so I am looking at two choices: which 1 should I go with? again moderate overclocking
H80i from Corsair: http://goo.gl/I8lc5Q
OR
Noctua NH-C14: http://goo.gl/L7j154
Thanks!
