Hey
So I am stuckk between the following cpu coolers
Enermax t40 vd
Coolermaster 412 slim
Artic Freezer Extreme rev2.
Noctua NH-U9b SE2 f (2x 92mm fans)
I want to OC my CPU to around 4.4 - 4.6 Ghz if possible. Recommendations?
Thanks!
Hey
Enermax t40 vd
Thanks!
Whats your budget and current case?
I posted some air coolers into this thread: http://teksyndicate.com/forum/cpu/good-air-cooling/128819
Also, why are you overclocking it?
yo thanks for the reply Im looking to keep the cost under 50 euro's (unless the performance will be so significant that its worth splashing extra).
Case will be the nzxt phantom 410 and I it will be overclocked to help me achieve some 1080p streaming capabilities (hopefully)
Thanks again!
