CPU cooler for FM2+ APU ITX?
I'm looking at getting the Gigabyte FM2+ A88X ITX board for an upcoming build. The only issue I am having is trying to find a CPU cooler that will not break the bank, but keep the new Kaveri A10-7850k APU cool and quiet. Was looking at some Noctua heatsinks, but there is only a couple that say they will work, but I'm worried about interference with the PCI-E and RAM slots. Not going to be putting a GPU into the build initially, but a few months from now, I'd like to put an R9 270X or GTX 670/760 into it. Can anyone help me find a good cooler. I'm going to be using the Corsair 250D, so it shouldn't be a problem with tower coolers. Already looked into the H100i from Corsair, but thats $100...
how about a cheaper corsair AIO liquid cooler like the H60 or H55 or even the H80.
i don't know how well those will fit inside the 250D. I could always try using a 120mm or 140mm AIO on the front on the case, just don't know how well that would affect temps inside the case. could be fine
a hell of alot  better than the H100i since they are mainly one fan radiators.
Only around 90mm cooler headroom for air coolers so not much room actually. If going water cooling I'd give the Water 3.0 Pro/Performer a shot
