CPU Cooler Compatibility Xeon
I’m trying to figure out whether this Noctua will work with my Intel Xeon 4410Y processor:
https://noctua.at/en/nh-d9-dx-4677-4u
The Intel site:
Suggests it comes with a E1B package carrier and the Noctua site suggests E1B compatibility. But it seems like Noctua is only providing support for Workstation CPUs and not Scalable.
I contacted them, but have received no response. At least so far. It has been 3 days I believe, maybe they’re inundated. Either way, does anyone know if it should work?
Anything that is 4677 in the lineup should work with both server and workstation. The website also mention explicit support for Xeon Scalable CPUs:
The new DX-4677 line coolers are dedicated, customised solutions for Intel’s professional LGA4677 platform, which makes them an ideal fit for both 4th generation Xeon Scalable CPUs (Platinum, Gold, Silver or Bronze) and w9, w7, w5 or w3 series Xeon processors for workstations.
Thanks, I didn’t read that part of the fine print!
