CPU Cooler - Aorus B650 itx in Fractal D - Terra Case
Looking to build 7800x3D / ProArt 4080 in the Fractal Designs Terra Case - my single concern is the cpu cooler - which needs to be a low porfile so I’m leaning toward the Noctua L9a - can anyone confirm that it’s compatiable with this MB?
I would go with the l9.am5, but the basic answer is yes, not sure if this is sufficient though. I would switch to either 7900 or use a NH-L12 and a GPU <= 50 mm high for the Terra.
