CPU cool or quite? (running silent at 45C?)
Hi Tek Syndicate team! My computer is in a low end case with crappy fans and a stock heat sink. My CPU is an i5 3570k, running at stock speeds and voltages. I recently took out my only case fan (the case has plenty of vents and holes) because it is very noisy. I love the silence but my CPU now runs at 45C idle and 65C under full load (prime 95 for 10 mins). With the fan, idle temps are about 15-20C lower, but under load, temps are about the same. Do you think the high-ish idle temps are worth the low noise? Is it bad to run it at such high temps all the time? Also i don't plan on overclocking (my mobo can't), and i can't buy any new parts.
Thanks for the help!
PS. love the show.
Those temperatures are just fine. Congratulations on a quieter system. :)
Which model of case is it? It's generally best to have at least a slowly rotating exhaust fan, but if for instance it has holes in the top then it might do just fine without for your current setup.
