Hello all. I want to build an offsite backup server that will connect in a regular basis to my main one by wireguard (or tailscale, but should be the same) and do an rsync (or zfs-snapshots). I will have a 500Mbps symmetric fibre at both ends, but I want to be prepared to do 1Gbps if cost difference is not much. What CPU power will I need to do 500Mbps and 1Gbps VPN transfers?
Not as much as you’d think. I have an HP Prodesk 600 G3 with an Intel 8500 running Proxmox. I have a VyOS VM in it with 2 vCPU and 1Gbps transfers pins one core at almost 100% on iperf.
I’ve not done much rsync, etc benchmarking, but I’d be suspicious if it was more resource intensive than 1 gig over wireguard de/encryption.
Wireguard does not use AES, it uses chacha20, so you don’t need to spring for a fancy modern CPU with AES-NI or anything since it won’t be used. Chacha is fairly lightweight and outperforms AES even on systems with AES-NI.
Why only one core? Does not scale with cores?
I don’t know their choice on core determination, however, the VPN took less than 1 core of a mid-tier 7 year old processor in a retired office PC. I tossed in my experience because I thought it might be a good note to compare that most things would probably meet the goal and going crazy probably isn’t required.
Another interesting thing is ~50mbps was taking around 16% when I was connected and running iperf over WAN connected to the VPN. It did seem to scale decently well when the 1000 went to like 92%.
I’ve been curious to try again with a 10 gig iperf, though I haven’t set that up since so much stuff needs actual doing before idle curiosities are chased down.
