CPU Advice for Scrypt Mining/Gaming Build
Hey guys, I've googled around with this question and had little luck, so I figured I'd try here. I have built a few gaming rigs for friends so I sorta almost kinda know what I'm doing.  This is my first build for myself.
I'm looking to build a solid gaming rig (shooting for 60 FPS+ in current shooters, currently have one 1080p monitor, possibly a couple monitors in Eyefinity eventually) that can do some scrypt-based altcoin mining on the side while staying at or under ~$1000. Based on current availability, pricing, and mining performance I've decided to go with two R9 270X 4GB Gigabyte cards (I'm digging the three fan Windforce cooler in case I ever want to do a slight OC).
Where I'm hung up is with choosing a processor. Would running 2 of these puppies in Crossfire bottleneck an FX-6300/ FX-6350? If so, would an i5 (such as i5-3350P?) be a logical step up? I am not at all familiar with AMD CPUs, but the buzz lately seems to be that the 6300 is pretty good for the money so I figured I'd start there.
Thanks!
The 6300 is great performance per dollar and I don't think it'd be a bottleneck. A 8320 might be better performing but not quite as much a bargain as the 6300. Looks like it's about $50 dearer than the 6300. If you plan to overclock the 8320 it's roughly the same as a 8350 but for cheaper. As far as the Intel chip goes I'm unsure.
Looks like the 8320 can be had for $150 (way less than any i5) so I think I'll just go with that and give myself some breathing room. Thanks for the advice!
8320 is also a great pick, especially if you're on a budget.
Sweet, it's a great choice. Just make sure you pick a decent AM3+ motherboard. If you grab a cheapy Asrock board you will make me cry. One of these boards would be my choice (I have to Asus)
http://pcpartpicker.com/part/asus-motherboard-m5a99fxpror20 $125
http://pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud3 $130
http://pcpartpicker.com/part/msi-motherboard-990fxagd80v2 $165
+1 on the Asus M5A99FX Pro R2.0
After I read your first reply I actually went ahead and ordered everything, but by chance that Asus board was the one I had already picked out!
Here's the full build I went with. Just have to wait 10 years for the Gigabyte 270Xs to come back into stock (i already placed the order for them).
http://pcpartpicker.com/user/opiclops9/saved/3q2g
