Hi Teksyndicate!
I have a Tacens Valeo 800W 80 plus Silver, and a 4670k (4.1 ghz, base tdp) two Hdd, one SSD and one 7970, my question is, Amd recommends a 1000W PSU in order to make CF, do you guys think I should get a new PSU when I buy other 7970?
Thanks! :)
It should handle it.
I think the reason they recommend 1000w is for those who are running lower-quality PSU's.
Nah you should be fine. You shoudlnt be maxing those cards anyway so they will probably never need the extra juice.
But if you do plan on oc your graphics then I would consider getting something with a little extra power. Just to be safe tho
