Could i get recommendations for monitors?
I'm looking to get a monitor that has a few features:
120Hz+
1080p minimum. I'd prefer higher.
Display port as the interface port.
I'm having trouble finding anything that's much better than the ASUS VG248QE(144Hz, 1080p) on Newegg.
Would y'all have any better recommendations? Are there any better options?
Yup.
"Yup" what?
Why do you want display port? If your video card has analog output, get a CRT. If not, then you should switch to a GPU with analog and then get a CRT. Never, ever settle for a LCD. That VG248QE you were looking at has atrocious color and contrast by itself, but on top of that, it has a matte film applied to it. The VG248 also cannot change resolution, has massive PWM flicker, and has severe motion blur unless you drop the refresh rate to 120Hz+Lightboost. A CRT has none of those problems.
I'm going for display port because I'm going to scale up to multi monitor displays.
The games I have and play do have advantages when using multiple monitors.
That "Yup." is hyperlinked.
To here.
I didn't even notice that. Thank you.
