Hey I just wanted to know if anyone knew how to remove the sink on corsair vengeance ram (http://www.amazon.com/Corsair-Vengeance-Desktop-Memory-CMZ16GX3M2A1600C10/dp/B006EWUO22/ref=sr_1_3?ie=UTF8&qid=1392582931&sr=8-3&keywords=corsair+vengeance).
Heat one side up with a heatgun. Pry it loose and repeat. It is glued on. Be careful not to pull the chips off the pcb. This will void your warranty. I take no responsibility if you mess it up.
Use a hairdryer if you don't have a heatgun. Look up a tutorial for it.
