Corsair M65 alternative?
Good point you're fucked bro, we ain't ready to defend from horse whips!
that Mionix NAOS 7000 looks realy nice ☺
I think I could see myself using the NAOS. I like the look of both Mionix mice. You don't think the ring finger rest will ruin my claw-like grip?
NAOS 7000.
Going once...
going twice...
i think not realy because most grip will come from your thumb.
But that Mionix Avior 7000 also looks nice,
offcourse its soo personaly.
I think you're right. I am using the M65 now, and I kinda think a ring finger rest would give me more grip if I were to use my finger tips. I just saw Logan's review of these exact mice (or meeeece!) and I am quite satisfied with the customisation software and the soft touch texture. Looks really good.
I think the ambidextrous Avior mouse might prove a little annoying for my kind of grip. Because the buttons on the right side don't really suit my finger placement. They would be in the way.
Do you mind if i ask a question about diffrent types of mouses in your topic?
Ive got a problem with my old optical mouse on a new wooden lacquer table, somethimes the mouse jumps away or just does not react properly.., since its a very old one, i decided that its time to buy a new one anyway, but my question for a lacquer wooden table, which type of mouse would be the best to use on this surface?
  1. Laser mouse
  2. Optical mouse
  3. Blue track mouse from Microsoft
And what are the diffrences in usage of a laser and a optical mouse? yeah the laser use a laser optical uses a LED, but  i wanne know which is better for gaming also.
Grtz Angel ☺
If the surface is opaque, it shouldn't matter. It's only transparent surfaces that optical mice would have a problem with. So any of the given choices will be fine. I assume that you would be more concerned with an ergonomic shape or grip preference.
But yeah, if the mouse is jumping around, it will be the sensor dying.
I'm still using my M65. It's ok for most games. Just a few that require precision that I really notice the acceleration problems.
yeah the problem of this new table is that they have put some wood stain on it (don´t know if thats the right word). i think that its causing the jumping and somethimes bad reacions of the mouse.
Best to test it elsewhere first.
...maybe get a mouse mat? :P
haha yeah i know a mouse mat would solve it all, but since this mouse is about 7 years old, i think it won´t hurt to buy a new one lol ☺
Anyway what would you prefer? laser or optical? :p
Ball mouse!
To be honest, I don't see any drawbacks with optical. With the exception of not being able to use optical on a glass surface... as if that matters?
No that doesnt matter i will not use in on glass or a mirror.
i was looking at the Razer Abyssus by the way, its not to big grip seems okay.. 3500 dpi optical. But i read diffrent reviews about Razer.
Appears to be a good price for that mouse.
yeah its basicly a bit cheap for a gaming mouse arround €32. But for me it doesn´t have to be that hightech as long as it react´s good. The only concern was the optical on my table, but i guess you are right earlier, my optical is probably dying, or just be retared, its an old Trust
Erm... it is Razer. Ewww. lol
No its a very fast and Decent Trust 450L Designed for Windows 98 is on the box lol ☺
The last time you used red font you got a little bit naughty. I have to ask you to behave yourself.
okay okay i will try ☺
