Hello all, i have a corsair k70 (not the RGB version) and was wondering if it would be possible to charge 5 different devices (phones specifically) on a USB hub connected to the K70's USB port
Perhaps if you plug it into a USB wall wort. That can supply 5A (1A per device) or 2.5 (0.5A which is USB 2.0 standard) a single USB 3 port can supply 1A I believe.
Possible yes, recommended or good idea no. The charging rate would be painful if you don't start a fire.
Hmm, might you possibly recommend a USB hub that i can use just plugged into a power strip?
Im not really sure what would be needed in terms of specifications for it, my only requirments are to have atleast 5 ports and the usb hub be able to be 3 feet from the plug (so it can reach my desk from the power strip sitting on the floor
