Makes me want to build a tiny system that's so cute.
I'm pretty sure that I remember them demoing something like this a little while back at computex or something. They had a whole system built around it. You should look into it. Likely a great option if you can find the case they designed this to go with.
its really nice
I think we need agent beard to test this out on an 8320E, APU, and intel chips.
looks like you need to mod the case to mount this in it.
Side question, does it explode when you reach boiling temp ?
Screw the 8320e, try the 9590.
You think it could handle that and keep it under 70C?
AMD's temp sensors suck, but I think probably.
No lol They use a special coolant.
Your coolant should never reach 100C under any circumstances. Sure, your parts can get to 100C when pushed hard, even when water cooled, but the coolant itself will never get that hot. It is the gradient between teh cool coolant (which is kept cool by the radiator) and the hot components which allows the cooler to work effectively. If the coolant was 100C, then your parts are WAY over 100C. And I don't know of any chips which can run that hot. They will all throttle immediately. So it should never get that hot.
P.s. Used 100C since it is the boiling point of water. If they have additives in the cooler, then the boiling point may be high or lower, but I would guess higher.
Tehe, it don't fit in a SG13. I am sad. :(
