Corsair h100i
will this case fit the corsair h100i pcpartpicker.com/part/apevia-case-xhermesbl
Do not quote me on this but most likely it should fit hopefully someone else reply's with a sure answer.
yes it will you need to take out the 2 x 120mm Top Black Fans (included)
okay thank you
