PC:
cpu: fx 8350
gpu: asus 7950 directCU II Top
mb: asus sabertooth 990fx r.2.0
psu: coolermaster gx lite black 700w
ram: 8gb kingston beast 1600 mhz
Hello. I'm thinking of buying a new cooler because the stock one is really loud. I have always planned to switch to water so I could overclock once I had the money but I went a bit over the budget when I bought this machine and I had to cut back on the case, I have an Aerocool vs 3. I have 3 questions:
1) Because the case does not have support for upper fans or how are they called, can I install the h100i or kraken x60 radiator on the side panel as it has room for 2x 120mm fans or 2x 140 mm fans ?
2) If the above cannot be done, do you think I have room to drill some holes on the top of the case so I can fit the radiator and do you think it can be done ?
3) If I can do one of the above, which cooler do you think would be best for me the h100i or kraken x60. I realise that this question is like asking which is better intel/amd or nvidia/ati and I have watched logan's build with the fx 8350 as you can see my pc is pretty much the same.
A thing I'd like to add, the x60 is really hard to find here in Romania and is substantially more expansive than the h100i.
I really hope it can be done as I plan to overclock this machine and I really dont want to do it on a air cooler, which i dont think will fit in the case anyway (a good one I mean).
Thanks in advance.
