I recently was looking into switching to a water cooling to cool my system. The issue is the whole system could get costly so i was considering water-cooling either the GTX770 video card or the CPU. I already currently have an H100i liquid cooler installed on my CPU.
So i guess my real question is:
Do I build the water cooling system for my graphics card with intent to expand to my CPU eventually and keep the H100i on my CPU for now?
OR
Do I try to move the H100i to my GPU on my GTX770 (if possible I know NZXT G10 bracket doesn't work) and water cool the CPU?
Both options would not require moving the H100i radiator in the case, but i would have to add a 200mm Antec radiator made for my case. it mounts under my 200mm top exhaust fan
http://store.antec.com/Product/accessories-other/200mm-radiator/0-761345-75210-7.aspx
Finally is that 200mm radiator going to be capable of cooling both my CPU and my GTX770 (with room to upgrade to a full water cooled card GTX 780, GTX 780ti etc). My end goal is to have worked up to a full water cooled efficient rig that has plenty of room to upgrade graphics cards. I wasn't really planning on SLI at this point because I am currently running a Raid 5 with 4 3TB drives and if I expand to 8 drives like I want to I will need a raid card which looks like it will give me SLI space issues on my Mobo, but that is at least a couple years off yet.
Since this is my first water cooled build I would like to here any ideas or parts suggestions you guys have!
Here is a couple pic of the inside, you can see at the very top the 200mm fan that the 200mm radiator mounts under.
https://www.dropbox.com/s/nxwusfr343b1fb8/Cooling%201.jpg
https://www.dropbox.com/s/3hk3zvmk61fius3/Cooling%202.jpg
