My corsair h100 fans is so laud!
I want to buy some new fans buuut. there is so many to buy!!!!!
I have looked at the corsair PWM high pre. and the noctua NF-F12 PWM Is there any fans there is better better then these? or wich one of these sould i get?
Does it sound like a grinding noise? Also go for the noctua NF-F12 PWM. They're less noisy
it is not like that noisy. i just wont some fans there is less laud!
What you do, is buy some fractal, noctua fans. for your radiator.
Cooler Master Sickleflow fans are supposed to be good and quiet on closed loop coolers and the corisar SP120's but i do like noctua fans (i just have to live with 70's brown color fans in my case)
A very affordable method is cougar 4 pin pwm fans. http://www.newegg.com/Product/Product.aspx?Item=N82E16835553006
I heard, those fans get really loud after a while
