Corsair H100 and Antec 1200 V3
Are these two compatible? If not what other full case is great quality.
I did research on this before I built my computer, and it's not compatible unless you mod the case somehow. I ended up going with the HAF X instead.
I had a 1200V3, it does have two rear exhaust fans, but the top one is too close to the top of the case for the H100. Looks like it could fit, but a H80 or other single rad loop is the only thing that will fit (on the bottom of the two)
